91 N/A was running rough and it stalled out on me, now it will not start. I recently replaced the CAS and it was not adjusted correctly which probably caused the car to run rough. I pulled the plugs to check for spark and the tips were black. I replaced the plugs and I do have spark when I spin the CAS. I checked to make sure i have fuel coming out of the fuel filter and all is good. I checked the ECU for errors and I get a code 55. What else is there to check for?
Thanks!
Stalled and won't start. Code 55 - TRdave20:27:20 07/27/11
